1 - 20 of 20 Posts
Hello all just wanted to ask what would be the best stuff to clean the MAF sensor, i thought i could use brake cleaner but apparently its really bad for it my friend said! Just want to know what people would recommend
Thanks Chris :smthumbup
I used electrical component cleaner with no issues
I already had issues with a maf sensor and I bottled it and bought proper maf cleaning spray after ready why not to use brake cleaner. £8 tin of proper spray vs £300+ for a maf sensor
I just want to know which one to get, could someone give me a link so I can go and buy it from Halfords or maplin etc, I keep going to get one and someone says don't use that on it :wallbang:
Please someone help me :cry:
You don't clean them.
They don't get dirty.
It's NOT
A MAF
It's a karman vortex volume airflow meter.
A MAF is totally different.
If you try to clean it, you'll **** it.
It's NOT
A MAF
So what happens when it get coated in oil vapour or general dirt through the air filter? Do I have to buy a new one?
Fit a proper air filter so it won't happen.
Where would the oil come from?
Realistically, whatever is wrong with the car, you've made a mis diagnosis.
Discussion Starter · #19 ·
The car is standard and I have fitted the proper HKS Panel filter and as above it breathes from the cam cover
oil comes from the cam cover breather.. it is perfectly normal and you can see it on any evo..
The airflow meter only flows air.
Blowby doesn't go through it.
If it does, then you've put it together wrong.
1 - 20 of 20 Posts
