1 - 2 of 2 Posts
Okay let me start here. Im so confused.
I replaced the IAC motor cause it was idling like poop (sounded like it was cammed and missing and bounced between 900-1000rpm also unplugged it and nothing changed.)
So installed a new one and now it works great on cold starts idle doesn't drop or stall when I step on the clutch but the problem is it still bounces and jumps like it did before also sounds the same sometimes but the new thing is that at times it jumps between 900 and 2000 Rpm I can't figure it out any tips?
Try adjusting your Speed Adjusting Screw, it's a recessed plastic screw located on the top of the throttle body.
Also look for vacuum leaks.
1 - 2 of 2 Posts
