Hi mate, I purchased from demon tweeks was told these would be a direct fit?Are they new? Where did you purchase them from?
Would I be safe to use 6mm spacers on the original studs?I always thought with that style wheel and fitment 6mm spacers were needed
Just checked and definitely 9.5 / ET30. strange as I see most run this set up?You sure they're 9.5? I had these wheels (in my avatar in fact...), and while the spokes came fairly close, they fitted fine without spacers.
I was under the impression the B1 would clear brembos too, I'm friends with the owner/supplier of Bola wheels so I could ask if you want me to... :smthumbupHi mate, I purchased from demon tweeks was told these would be a direct fit?
Appreciated, confused as most run the same set up but definitely don't fit, Bola confirmed the order and agreed with the fitment before purchase?I was under the impression the B1 would clear brembos too, I'm friends with the owner/supplier of Bola wheels so I could ask if you want me to... :smthumbup
I think the big brake kit might be a little excessive but im looking into spacers as we speak. :smthumbupI know that the rota GTR similar shape need the spacers with brembo so assumed these would too.
get a big brake kit or hub centric spacers with extended bolts
Hi, just got back after a test drive and can state all is fine, no rubbing :smthumbupIs there any rubbing as a friend of mine running same size wheels on his ruri blue nine and he had to have arches rolled be interested to know outcome as I'm after a set of b1 in white for my mr hoping to go 9.5 but don't want arches rolled so was thinking 18 x 8.5 be nice to get update when fitted:smthumbup
That's the joys of fitting 9.5" rims :lol:As soon as people get in the back and you take spirited bend they will rub .
Nobody allowed in the back :crackup::crackup:As soon as people get in the back and you take spirited bend they will rub .
