Just getting round to fitting my tein springs on my evo 8
The front O/S has a blistein front leg rest is standard
Will this be ok? as all springs will be tein?
Or do i need to find a standard leg?
No! it will and is now causing imbalance both across the front and stability front to rear diagonally. Recommend either changing that strut to match others or replacing the other three to match that one. Make sure whichever way you do it you get four wheel alignment done to get the best from the set up.
One blistein? That's pretty random. If the teins are for non mr (not bilstiens) its my understanding it won't fit so you will need another stock shock
