please tell me if theres such a thing as a motec plug and play for the evo 8, because a forum member is telling me there isnt???
There is and there isn't I think...
You can get an M800 ready with looms with the relevant plugs on so it plugs straight in. However, I don't think they come with even a base map at all so you won't be able to 'play'!
I'm sure I read in Banzai that there is. I will read through my collection & let you know mate.
I could be wrong, but am pretty sure I saw this a few months ago
Thats what I thought I read aswell!!!
I am running an E8 OEM Motec M800 now for my MR
I believe it is the same one used in the FQ400.
No need for looms. Uses back the same ECU connectors as the stock one.
You can order it board only (need to remove yr existing ECU board from the ECU box and swap the M800 OEM inside) or you can order a replacement box from Motec, I believe.
