Tried doing a search but the site just kept crashing on me......:confused:
Is there a post anywhere about the removal of the front bumper on the Evo 8 and where all the bolts and clips are etc.
Chris
you need to remove the clips on the undertray around the front, there are 2 bolts and 2 push clips at the top between the lights and a bolt in side each front wing. Remember to unclip the water hose and that should be it, then just a quick pull and it should come off.
Andy
As well as what And said...
You will also need to take the number plate off. Only undo the two plastic screws that hold the plate on. Behind this you will see a bolt (similar to one on offside). Undo both near side and of side.
:smthumbup
