1 - 10 of 10 Posts
Hi has anyone got a base map for a evo 8 2.3l with 272 cams they are willing to share so i can get my car running.
Id imagine if you said what ecu, Injectors etc etc you may get farther. Although can thr mapper not supply/load one for you?
sorry standard evo 8 ecu 1000cc injectors.
BAD BISH
SD kit, Yay, nay?
Easiest way on stock ECU is to divide injector scaling by 1.15, so change your injector scaling from say 1000 to 869. That will inject the extra fuel needed and get you close to the right fueling.
Then you remap with a wideband from there.
What about the fact it's a 2.3 and has 272 cams I need a base for the timing and fuel do I not?
The injector scaling fixes the engine displacement.
For the cams, increase idle timing to 10 deg and if that doesn't do it, then increase idle to 1000rpm and if that is not enough, richen idle fueling.
Sent from my TECNO-C9 using Tapatalk
Cool thanks at last a good answer
1 - 10 of 10 Posts
