Hi all i have had this 7 about 3 weeks and getting bits sorted for the summer so i can just burn up some road lol , problem is i cleaned the aftermarket air filter and tightern up the bolts and secured it properly , now it dosen`t pop air off throught the gears which is good as its not dragging in too muck air ,the only issue i get now is when i come to a stop and press the clutch and brake peddle the revs hit 3k+ so i let off the brake peddle and it drops not too sure what the issue could be as im not that mechanically minded , i can do easy general stuff but wont get too involved , could it be an air leak some where or a loose pipe / hose as i tightern up the inter cooler clips and a few other and pushed then in properly the car is 80% better so must have stopped an air leak some where , any more info would be greatful .
