Guest
·Hopefully someone can help. When I take the car to the local Mitsubishi dealer and they test drive it they can't find the fault. When you drive the car a lot you notice it.
Okay, there seems to be more than normal road noise from front of car. When pulling away from standstill at a roundabout for example, the steering seems to judder slightly. It only does this at very low speeds and it's annoying. I found that the car had different profile tyres on front and rear so thought this could be fault and had same tyres put on all around but it's still there so don't think its diff getting wound up.
Anyone experienced same on 99 GSR? Also, with 28000 miles on the car, would you expect the cam followers to be noisy? My previous car (escort cosworth) had same problem after only 60 000 miles
