got evo with oil light on at idle changed mains bigends and oil pump and still the same? has about 15psi oil pressure at idle from the head at turbo feed? is this norm or low? i know you should more at the main gallery but maybe this is all you would see at the head?
So basically you have 1 bar at idle? My brand new gauge/sender reads just over 1 bar at idle. (reads from sandwich plate), which I believe to be perfectly normal.
