There is a sealer that you can buy that people use to seal around light clusters, put some inside where the leak is coming from. IMO
Silicone could also be used but not if you are planning to repaint your car boot in the next couple of months.
PS i don't know if there is a seal that you can replace
Hope this helps
No i'm not saying that you would need to, it's just that silicone and respraying don't go well togeather as the silicone reacts with fresh paint causing ugly little pit marks.
What i meant was that if, say for instance you were planning to get some paintwork done over the next couple of months, you would be better off painting the car first and then using silicone on the boot.
