1 - 3 of 3 Posts
Is there a way to control/map the AYD on Evo 6 (TME) as it is the case with later Evos on the center diff (you can buy Motec plug and play diff controller)?
simple answer is NO as the centre diff if fully mechanical on a 4/5/6 & 6.5
if you want to change the balance you need to fit different dif
I know that but I was talking about the rear diff. As it is electronically controlled, I was wondering if there is an aftermarket ECU available for it.
1 - 3 of 3 Posts
