1 - 10 of 10 Posts
Hi
Selling this on behalf of my brother his E5 GSR Silver, full spec and pictures below, tried to show as much detail as possible, sure there might be a few things that have been missed, sun strip has now been removed as it was starting to peel.
Car is used as an everyday driver, please contact me on here via PM if you're interested.
Mitsubishi Evo 5 - Silver
R Reg 1998
4 Former Keepers inc current owner
Mileage - 90,000 (will rise slightly)
Looked after and Fully serviced by MG Autos, CPP and ABP Motorsport
MOT until November 2017
Mods
Engine
3mm Lash Adjusters
3 port boost Solenoid
Walbro 255 Fuel Pump
HKS Reloaded Intake Kit
Evo IX Recirc Valve
Evo VIII Actuator
Timing Belt and Tensioners replaced Dec 2014
Water Pump replaced
Water Pump replaced
Samco coolant hoses
S/S Power Steering Pump heat Shield
S/S Exhaust Manifold Heat Shield
Koyo OEM Spec radiator fitted July 2016
Ralliart 1.3bar radiator cap
Ralliart radiator bushes
S/S Spec R Slam panel
S/S Coolant Tank
S/S Power Steering Tank
Refurbed AYC Pump fitted
Crank Shaft Pulley replaced 2014
ECU Remapped by MG Autos to take into accounts mods etc - not put on RR
Still running on standard engine with standard turbo and diffs
Suspension
Full Superpro Polybush Kit
Front and Rear Ralliart Top Mounts
All 4 shocks replaced with Bilsteins (Dec 2014)
Tein Lowering Springs Fitted
Front and Rear Strut Braces
Titanium 3 point under brace (supplied by Ross-sport)
Transmission
Evo IX Clutch Kit and Flywheel
5 speed GSR Gearbox swapped Sept 2016 due to original starting to crunch
Rosssport Gear selector Bush
Ralliart Gearstick cradle bushes
Clutch and Slave cylinders replaced
Brakes
Hel Brake Lines fitted all round
All brake calipers serviced and re-lacquer Dec 2014
Front Giro Discs Fitted
PF.01 pads fitted front and rear
Exhaust
Hand built V-Band exhaust fitted by JR Race Fabrications - catback (track friendly)
200 cell Sport Cat
S/S Downpipe
Wheels and Tyres
2 Sets of Wheels -
1st set fitted with Goodyear F1s
2nd set Original E5 Wheels fitted with Winter Tyres
General
All 4 x door cards have been flocked
Carbon Rear Exhaust trim
MLR floor Mats F&R
MLR Seat Covers Front
Quality Extra Boot Mat
Ralliart Pedals
Ralliart Gear Knob
Cobra Alarm
Couple of signs of surface rust showing but all kept under control and treated
Price - £9,500
Located Stoke on Trent
Cheers Mark
Cheers mate, he's said he'll keep it if it doesn't sell after all the money and time put into it, but he needs something with a few more creature comforts and still a few issues with the neighbours even with that exhaust :/
1 - 10 of 10 Posts
