Hi all,
I have some oem bits from an old shell. They have been removed from an evo 5 GSR and now I'm working on a full track day project so I'm not going to use all this stuff.
I will update the list as I clean the garage and see what can be sold.
Bits:
Front wishbones
All rear arms.
Alpine Radio with wiring (Sorry I cant remebrer the model but I have pics).
steering column without ignition switch/lock
Pair of side sills with carbon trim at the end (White)
White Side indicators (x4)
AYC ECU
Accelerometers with bracket
Set of brand new Innovative mounts (engine - gearbox) With poly bushes rated +500hp
Front and rear ARB poly bushes for standard size ARBs
HVAC/Aircon Unit + vents + dash panel/control unit
LH tail light (Small dent in one side)
x2 sets of OEM pedalbox including clutch pedal
Handbrake lever
Set of OEM belts with all fixings/tensioners etc.
front/rear wipers (no blades)
Cup holder
x2 alpine speakers
glove box
AYC reservoir
2 pod side pillar
EVO 5 Rear wing
x2 garnish lights full red
rear crash bar/bumper mount
Lots of interior trims and plastics (ask if you need anything in particular).
ABS unit
Bonnet Vents and heat shield
Clutch master cylinder
Brake master cylinder with servo.
I know the value of all this stuff but I'm open to offers as it needs to clear within a month or so. I can deliver anywhere in UK. Collection is possible if preferred. Parts are located in Dovenby- Cumbria.
As you can see is my first message here so I still need to figure out how to upload pictures,in the meantime, you can send me a whatsapp message on 07572780404 asking for pictures or any doubts.
Front wishbones and rear arms have been sandblasted and painted, all joints are like new and also the bushes. Need to clear out so they are 60 each delivered.
thank you
It is what it is.
I've sold a few bits to Alex in the past. He's a top guy who doesn't mess about. If people have any doubts due to his low post count then they have nothing to worry about. :smthumbup
Good luck with the sales and with your track car Alex.
Thank you very much for the feedback pal. I will post some pictures of the car when finished. now is in the paintshop for the last details in red:naughty::mitsi:
