It's a direct bolt-on type and no need to do any modification. Of course, you need to change the rim. Mine fit Evo5 rim and caliper and that's great.
Booster,
You say they are a straight bolt on aplication ,with achange of rims to say 17 ,are there any other adjustments that need to be made.
Say if I were to purchace a set of front calipers and discs from an E5/6 theres no hidden problems that would occur.
I have an E4 and looking to do this in the near future.
cheers
No major problems fitting EVO 6 Brakes to my EVO 4, apart from using EVO 5/6 wheels, EVO 5/6 Brake lines. Purchased from RPM Motorsport in Ware (Tel: 01920 460800)
Only problem is cut away smaller back plate on rear discs, other than that 2 hours max fitting all brakes.
How did you get the E5/6 wheels to fit the offsets are completely different,did you uses spacers or something?
