1 - 11 of 11 Posts
have a word with guy (oilman) on here m8 he will point you in the right direction.
engine oil: 5w-40 or 10w-40 fully synthetic
g-box/transfer box: Hypoid gear oil 75w-90 GL4/GL5
rear system:
Diff: Hypoid gear oil 75w-90 GL4/GL5
clutch bath: ATF SP-III or Diaqueen AYC oil
actuation system: ATF SP-III or Diaqueen AYC oil
Thanks for that,I was getting a bit worried there! Should I flush the engine before changing to a different grade of oil or will it not matter that there is 2 different oils mixing together? Thanks in advance.Chris
oil
whats wrong with 10w-50 this is actually what 'oilman' recommends ie silkolene pro S..!?
The book recommendation is 10w-40 or 10w-50.
With the trackdays I would suggest a 10w-50 may be a better choice if temps are high.
Look at Silkolene PRO S 10w-50 or
Motul 300V 10w-40 Chrono
Tech data here: http://www.opieoils.co.uk/lubricants.htm
Oh and dont flush it unless you do it with normal oil, ie NOT flushing oil..!!
Dan
Re: oil
Dan
nothing wrong with it....book recommendation etc
as you say...good for high temps.... e.g. trackdays
I also suggested 5w-40 as that's recommended for e5 onwards
as I was assuming that the car was going to be used only 'on the road' .......
1 - 11 of 11 Posts
