Thanks for the reply,i don't know why they put a plate under the rear seat if you can't remove the pump from it its just a tease lol.
NO YOU DONT ,do it through the inspection cover its FIDDLE but doable
thanks for the reply have you got any tips? ive disconnected the 2 hoses that are connected to the hard pipes thats stopping it coming out but still can't get enough height to get it out :wallbang:
You have to cut pipes trought inspection hole, and after fitting new pump connect pipes using about 5cm pieces of fuelhose and good clamps. 6mm and 8mm hoses should fit
