Got an evo 4, original engine. It has a fujitsubo downpipe/ 3" decat to a hks silent hi power exhaust and a sard cone air filter.
Its still on the 4 ecu (metal case so assuming) and the 4 injectors.. i've read that i'd need a remap and bigger injectors/pump to run this sort of boost level due to it not being able to supply enough fuel and a map.
Just wondering if there is any way to lower the boost level without putting an airbox or cat on? Is it possible to fit a manual boost controller to drop it? or maybe fit a 2.5" decat to provide abit of a restriction in the exhaust.
I dont have the money to go with a 5 ecu/injectors/map yet but i have got a trackday booked fairly soon and dont want to be melting a piston
Also forgot to mention, it never hits fuel cut and the EGT's never go above 800° usually around 770° on a 3rd/4th gear pull up hill
Some let go at 0.9 bar, some are OK higher. Nobody knows the answer as it's car/engine dependant. I ran 1.3 for a while on my old IV engine with no issues. It even hit 1.7bar a couple of times when my actuator was goosed.
Now run 1.6 but on a later engine.
Probably will get it checked on a dyno somewhere, i've had a rough estimate for mapping plus the supporting mods required on a 4
what did the quote involve, i'd have thought your easiest route would be later ecu and injectors then remap, though you cant push a 4 engine too far. Have you checked the engine number, to make sure it is a 4 engine, and not had a later engine fitted at some point in its life?
Also I maybe wrong, but I'd have thought 1.15 bar isnt much more than standard??
Agree though, at the very least, get the fueling checked on a dyno, then you at least know that side of things is good
You could lower the boost by fitting an external boost controller if you do want to lower it
Stu
Quote was for a 5 ecu, injectors, fuel pump and mapping.
Im not after more power, i just want it reliable
