1 - 8 of 8 Posts
I know of a block but cannot match the engine code up, how is the thrust bearing setup different, how to tell? Any pictures or descriptions would be great.
On the 4 there's an integrated thrust and centre main bearing, on the 5 and up there are separate thrust washers in the block side only.
Cheers,
Simon.
can anyone put a picture up of a 5 block with differences showing thrust washers , do they still have main bearings plus the thrust? here,s the codes mate
EVO I:
EVO II: OP
EVO III/IV: TB, TG, TH, TJ, TK, TM, TN, TR, TS
EVO V: NK, XL, XQ
EVO V/VI: CA, XG, XM, XO, XS, XU
EVO VI: AA (VI Extreme), AL, AN, AO, AP, AQ, YR, YT, YX
EVO VI TME: BB, BG, BL, BM
EVO VII: CS, CT, CX, DA, DB, DN, GN
EVO VIII 260: HY (USA), JX, KL, KO, KQ
EVO VIII: HM, HP, HQ, HT, KS
EVO VIII MR: KA, KD,
EVO IX: LB, LD, LJ, NB (USA),
EVO IX GT: LA, MN
EVO X: 4B
evo 4 start with TH/TN/TS/TK/TM/TJ,
evo 5/6 start with XO/XU/XY/XG/XM/KS/CA
evo 8 start with YX
4 has thrust washers as part of the centre bearing in the block and in the cradle , evo5 on only has thrust washers (separate to bearing)in the block ,none in the cradle.
ok so when buying the main bearings for the evo 4 , u buy the main bearing set for an evo 3 , like the dsm 2 generation ??????
ok done thanks ,
evo 1-4 same main bearings
acl for evo 3 here i come ...
thanks TODD man .... can u beleive i called acl they told me evo 4-9 the same bearings for main .. :mhihi::mhihi:
1 - 8 of 8 Posts
