1 - 3 of 3 Posts
has any 1 ever used the alcon heavy duty clutch cover n 6puk sprung clutch plate?? lookin at buying a new clutch for my e4 n these are very good price at min from demon tweeks,, just looking for a bit of feed back from ne 1 thats used or knows some1 that has, for a daily drive that gets a good seeing to :) cheers in advance
I'd be slow to put a heavy duty clutch in a 4 with original engine, it can (not saying it will) lead to crankwalk due to more pressure on the thrust bearings. I find the original one fine, wouldn't do any launches with it but loads of bite between gears.
ohh rgt,,cheers for he info,,i was told its runnin around 370 bhp wen i brought it, bigger turbo 560 injectors fuelpump etc, norris design flywheel n ive got 4 receipts for budget clutchs in the las 18-20 months,, thats y i was thinking of uprating the clutch,, engine duz 71k n only had the converter fitted by mitsubishi in april 09 so its low milage,, wat can i do to prevent crank walk?? wat actually causes it?
1 - 3 of 3 Posts
