Hi everyone Im new here. My mate has an EVO 3 and we need some info. Weve just done a small overhaul on the engine bye fitting EVO 6 pistons, New std turbo with 360 deg bearing, New timing belt and metal head joint. The Spec is
EVO 6 Pistons
Std Turbo 360 deg bearing
Big Bore Hypermuffler
HKS Induction kit
Deecated
Rally Art ECU
Steel H/Joint
Its covered about 500 mls. The engine wasnt quiet running right after the rebuild but he had been taking it easy for the first 400 mls so it wasnt a problem. Hes now started to open it up more and there was a slight bit of dett in the higher gears and it wouldnt boost above 0.5 bar in the higher gears like 4th and 5th but would boost to 1.1 bar in the lower gears. So we looked at his timing and it was set at 10 deg BTDC. Weve now knocked this back to 5 deg BTDC at 800 rpm and the car flys now, It now pulls strongly in all gears. The boost peaks at 1.5 bar and then drops to 1.1 bar in 5th. Can anyone give me any advice on what settings to run this car given its spec.
EVO 6 Pistons
HKS Induction kit
Deecated
Rally Art ECU
Steel H/Joint
