1 - 15 of 15 Posts
· Registered
Ive heard quite a bit about melted pistons on the E4 and that the internals arent as strong as the E5 onwards .
At what BHP has your pistons failed ?
Was it because of high boost pressure or high BHP with a lower boost setting .
Ive been thinking of getting an Ecutek fitted to take my car to about 330 BHP ,but really interested in the torgue figure increase.and mapping out a smooth curve on a dyno graugh .
I'm alittle concerned about the expense if the pistons let go .
Currently have the gromet removed and a decat pipe ,and the car drives very smoothly ,much better that before .
· Registered
I killed my pistons at 15psi.
The only mods I had at the time was an exhaust and a cusco intake with a pipe from the front of the car ducting cold air into the air filter.
I think the main reason I killed the piston was because of insufficient fueling, as I had never bothered to check the fuel to see if it was ok after I had done those mods.
· Premium Member
Shorty,
Have a look at this thread in the Technical Archive, it contains some useful information and also some small mods which can improve the fueling.
Brian
· Registered
shorty,
my evo iv let go last week ( pistons) and the only things i had done to it were and H.K.S induction kit and a de-cat pipe.....
should be standard boost but would also be interested to know why this happened .. fair enough i was giving it max at the time but these cars are supposed to be designed to do this plus there is a rev limiter to stop you over revving them.....
· Registered
Spanpody said:
Shorty,
Brian
Brian
An interesting read .
Reading between the lines Its bad news to take the E4 above 1 bar with out injectors and pump being changed .
The internals can handle upto 340BHp with higher fueling .
My car is running max 1 bar [as do have a boost guage] when the air is dense ,I have standard airbox which i'm not going to change.
JAmie
Doesn't seem to be a problem with say a decat exhaust as this is removing gases .it seems to be the amount of air intake along with the amount of fuel being mixed together .
I had vta bov,blitz air filter, gromet removed on my previous E4 and stiil ran rich nice flames . Had no problems ran 296BHP on RR.
I had my boost guage replumbed last week as I was told that the way it was currently done would lean out the fueling .
I'm wondering whether to put the gromet back in .
What exactly does removing it do?
· Premium Member
along time ago now but i once blew an evo4 straight after fitting an exhaust and induction kit.again same fault. Broke the pistons and destroyed the block nicely for me while it was at it :cry:
· Registered
Also had this problem too, blew the pistons and con rods after only having the car a short time,only had the induction kit and hks blow off done at the time,replaced with an e6 engine and e6 ecu,hoping this solves the problem myself.since then the de-cat and down pipes been done,reckon it needs r/roaded and set up.yet to find somewhere south of scotland thats suitable.not many folk work around these parts work on them etc
· Premium Member
AVA in Glasgow, Star Performance in Glenrothes.
Both have rolling roads and can check fueling etc, we have used both for rolling road days, do a search on the forum.
Brian
· Registered
I run my IV at 1.3 bar. I have the following mods:
Walbro 255 l/hr pump
E6 cams
E6 GSR turbo
Straight induction pipe
HKS Super power flow induction kit
Decatted Blitz Nur Spec with 3" downpipe (had a decatted HKS Superdragger until 4 days ago)
Apexi AVC-R controlling the boost.
Denso Irridium plugs
I had the car on Star Performance's rolling road and got the following figures:
350 bhp fly
236.5 bhp ATW
300 lb ft
The fuelling was a little on the rich side throughout the run.
· Registered
E6 cams
E6 GSR turbo
350 bhp fly
236.5 bhp ATW
300 lb ft
Thats about where i'd want to go, I guess picking up s/hand parts would make it pretty cost effective as well.
· Registered
Well I'm not going to mess about with it untill I get a few parts together .
Or maybe look at the Ecutek with a new fuel pump .
Thanks for the info and input
Will look into it all a bit deeper when i get some cash together.
1 - 15 of 15 Posts
