1 - 10 of 10 Posts
Well I thought it was about time I started this thread as owned my E6 for over 3yrs now
Bought car as a standard E6 Gsr from Mitsubishi Fife
Traded in this
Received this
Now From this point on there was a few issues that needed sorting
First off the downpipe of exhaust decided it was time to fall to bits so replaced full system with a japspeed S1 system and turbo elbow
next up was a trip to Jamie at evotune for walbro new actuator and boost controller
Car ran faultless till low and behold clutch let go so searched for a new clutch and ended up with a competition 6 paddle
off car went to get fitted was happy again tho abit juddery in slow traffic all was fine
Then the enevitable happened I caught the sprint bug
2012 season seen a no bad set of results for car which I was happy with
came back from castle combe and car was in for a check up for a miss fire on the test drive the rods decided they didn't want to be part of engine anymore so new engine required
got some quotes and done some research and was decided car would go to Gary at APT
now as gary will tell originally car was only booked in for a new lump but as everyone knows things change :crackup:
Spec went from
2.0 LR Built & Fitted
80 Series
Exedy Twin plate as CC was Knackered Useless Finished 9 Months Use :shake:
and all mapped ready to go
To
2.0 LR
80 Series
Ross Sport Hardpipes
Pace Inter Boiler
Tial DV
Exedy Twinplate
Oil Cooler
Avcr
as you see I add things and Gary much abliged in supplying these parts:crackup:
Sorry No Pictures Of This Work :shake:
Car ran faultless in 2013 sprint series till Castle Combe ( you guessed it twice now this track has put my car out of action )
Now I do tinker with cars but as seeing Gary put all time and effort into building my car off went engine and gearbox back to Gary as I didn't want to damage his work and was unsure where my knock was coming from
Alas phone call from gary with his findings 5th gear and output shaft gone so box was stripped rebuilt
now on to where I am at just now some pictures
while engine and box are at gary's I decided it was time for a small tidy up of body work ect as it was looking tired
Now this is not a full resto Project as I am booked up for sprints this year this is to just tidy car up protect it till next year when the Full resto project begins ( Full Strip to bare shell and chemically dipped back to bare metal is the plan ) , before anyone starts asking why this and that's not happened :smthumbup
Where I Am At Just Now
ok so found myself a little unit and popped car up
Next was to strip few parts off and get to work
now as you can see surface rust has took its toll on the car so out came the tools and started work
arms now twice the size after there workout :crackup:
Even More
Products I am using is rust bullet
This morning sealed all the seams with Tiger Seal Seam Sealer waiting for drying before final coat of Rust Bullet goes over then its a case of fit front end back together and get to work on underside as that's just as bad :wallbang:
Fair bit of rust in the engine bay mate.
Doing a grand job,bet around 90% of earlies need this done.
Looking much better now, be interesting to see if the rust bullet keeps that rust under control, it will im sure :)
Ian
you don't even want to see the underneath then don't think this was treated right when it was brought in this country
Ian
will find out as next year car will be stripped to a bare shell and chemically dipped to remove everything again so we will see if it has stopped it :smthumbup
drivers arch after seam seal and black rust bullet
for some odd reason pictures not showing yet on photobucket for rest
I had all my underside done last year back to bear metal Nasty job but happy once mine was finshed off and looks good
yeah its one nasty job taking next year out from everything working like a mad man for a year every shift I can get and next year will be full on resto
1 - 10 of 10 Posts
