1 - 9 of 9 Posts
Hi all I need to get a new clutch and flywheel for my EVO 6. IT'S running 340bhp what would you recommend? Want to get better than standard.
Sent from my GT-I9515 using Tapatalk
Regional Organiser
Fit a Flywheel (maybe a lightweight) and a Standard OEM clutch as a pair - designed to fit the VII-IX :smthumbup
Will take up to 400/400 no problem and no down side plus won't break the bank. Feels 'normal' too and keeps the car easy to use for everything.
VII-IX Exedy Silver box clutch
http://www.rosssport.com/Brands/EXE...Clutch-Kit-EVO-7-EVO-8-EVO-9-MBK20-EXEMBK2084
240mm lightweight flywheel:
http://www.rosssport.com/Brands/TTV/TTV-Lightweight-Flywheel-240mm-Evo-7-9-TTV-0560
TTV Lightweight flywheel for Evo 7-9. CNC Machined single piece billet steel flywheel with integral teeth fully dynamically balanced. Made in England, 4.6kg in weight. Can be retro fitted to Evo 4-6 with corresponding clutch kits. Can be used with all popular clutch kits including Exedy, Helix and ACT.
Features:
- CNC Machined single piece billet steel flywheel.
- Integral teeth fully dynamically balanced.
- 4.6kg in weight.
- Made in England.
- Can be used with all popular clutch kits including Exedy, Helix, and ACT.
- 240mm.
FOR EVO MODEL 7-9. CAN BE RETRO FITTED TO EVO 4-6 BUT MUST USE 240MM CLUTCH KIT FOR EVO 7-9.
You are looking at about £700 fitted in total by a local specialist.
You could go for somewhere like a kit for an ACT Street light clutch and fly but that will cost you £700 just parts. I'd stick for OEM VII-IX set up at the power you are on.
OK mate thanks for that there is so many to choose from out there.
Regional Organiser
Yes and you will have lots of traders trying to sell you 'upgrades' all you need on that power is a standard set up suitable for a VII-IX as it's one reason why :mitsi: could produce the FQ-300+ cars in the UK. It can take up to 400 safely. win win for the same cost as an OEM VI set up. Mine is running just over 300 and I have the VII-IX set up I described. The lightweight fly does (very slightly) improve the acceleration but you need to give it slightly more throttle when you pull away I find. Once you are on the move makes no odds in my opinion. I went from a standard VI set up that I only 'upgraded' because the gearbox was already out at the time. :handsup:Saved on the labour.
As six shooter said people are quick to go for a upgraded clutch when the standard setup is perfectly adequate, I also run the same e7-9 240mm clutch flywheel exeedy 2084 & lightweight flywheel
Sent from my F8331 using Tapatalk
Yep, I have exedy silver box clutch and flywheel for the later evos:smthumbup
I'm running 377bhp. 370 lbs / ft.
Hi guys I got what was recommended all great and Ross sport were fantastic. Now what break and pads should I go for ?
I have performance friction Z rated pads front and rear and have yet to experience any brake fade
Drilled disks front and rear 2 piece fronts mintex fluid
Not used on track as yet but have had some good spirited drives 😁
1 - 9 of 9 Posts
