1 - 9 of 9 Posts
At most, should be around 4.8 litres. Engine holds a little more, but not all will be drained.
I noticed that the sump plug dosnt sit flat, its on the corner of the sump which will make it impossible to get all the oil out :mad:. I was worried that when the oil is changed there will still be dirty oil in there mixing with the new stuff :mad:
You'll never get it all anyway. It'll sit in all sorts of places. Oil cooler will also hold a bit. Change it regularly and it'll be fine. Could always flush the engine, but I'm not so sure it's a good idea.
True. I bought loads of Silkolene so ill give it a flush with that before refilling :smthumbup
engine flush is a good idea imho.
I wouldn't bother - waste of good oil.
As Dave said, change the oil regularly and you won't have a problem.
Cheers,
Simon
1 - 9 of 9 Posts
