Any ideas :confused: ? got a fault, engine m/ light comes on only when you put the power on, & engine seems to cut out & then ok when you back off, just had auto electrician round to diognose fault, all wiring was ok, but on tickover it was showing a reading of 5.84 m/s, as he said it should be about 2.50 to 3.50 m/s,he said it could well be the air flow meter. :confused: Anybody know what else would cause this to happen, thanks ;) .
Steven
You need to get the ECU fault codes read. If a fault has manifested itself it will have logged an error code. Armed with the code at least you know which direction to chase the fault. Otherwise you are just going to change components blindly until it stops.
Big Al
