Guest
·Just had the emission levels tested on my E5 (cat refitted) and the CO level is high, overfueling?
The HC level is about fine.
The car is booked into my local Mitsi garage for a check. What would you guys suggest is causing
these high readings ? Faulty Lambda / Oxygen sensor ? The car still runs perfectly.
Thanks in advance,
...Brian
Thanks in advance,
...Brian
