Guest
·I have been reading the latest CCC (December issue, good article on the group B rally cars) and saw the bit about Electric Water Pumps. I have seen them advertised before but wasn't sure of the exact advantages. CCC tested one on a CVH engine and noted a 4bhp gain at 7,000 rpm. The reason being that it works in relation to the engine temperature unlike the standard mechanical item which only works on engine rpm. Given that the cooling on the 4G63 seems to be an issue (hence the overfueling) I wondered if an Electric Water Pump might be a good idea? Has anyone tried one on an Evo? It might be worth investigating as it does seem a relatively cheap upgrade (£300 all in?) although you need to remove the old water pump impellor, blank the spindle hole and use a shorter timing belt to do away with the mechnical water pump (otherwise theres no point).
I just thought someone may want to try it.
By the way, having come back to reading CCC after several years away it does seem.....a bit naff? Anyone else noticed?
