pblamire said:
I see various people talking about replacing the MAF sensor and flow restrictions, so a few observations of my own.
The Nissan Z32 MAF sensor can only measure up to about 500hp worth of air, I know because I maxed mine out on my subaru and put the z32 sensor element into a larger housing.
The EVO used to use a frequency based MAF, probably still does, surely this would preclude the use of normal voltage scaled MAF sensors like the Nissan ones?
I have made "around" 550-600hp ([email protected])on a system with a 3" inlet. From memory the standard EVO MAF sensor is quite a bit larger than this.
Paul
hi paul
i am not sure what is the Max limit for the map sensor to be honest, never really had to max one out on an evo as i usually tend to use other ecus at this power level, motec,gems, autronics etc. i also know that turbulance can cause strange maf readings on the evo maf sensor with certain induction kits. i have seen cars go from rich to lean at the same boost. i think pat has experienced that too sometimes with ecutek. problem with the ecutek on the evo unlike the subaru is we dont have map access yet. something to do with the rate the OVD connection works on the evo being so slow to allow fast live map tracing.
TCB
this is the 1500£ question is not it
here is the way i would think about it.
ecutek, is easier and much quicker install were you know everything is going to work as standard straightout of the box.
dealers wont have a clue that it is there so could be warranty friendly.
boost control on the standard ecu is not very good so an extra boost controller is a must. that is another 300£
motec, is not mainstream. some people wear skenoda and some wear omega. both will tell you the time and you will get bored of both after a year!
it is more versatile, so you can take it off and fit it to an evo9 if you wish to do so.
it will allow better boost control out of the box, and using a map system is very predicatable.
it has got a lot more resolution so, theoratically the car should drive better and have slihglty more power.
at the end of the day, if both cars are teh same spec the difference in a power figure at the top will be minimal.
personally i would go the motec route but i am baised. until off course i try another ecu which i like more than the motec.
