1 - 8 of 8 Posts
AndyN said:
standard 6 rs - if i fitted autronics ecu what bhp would i get? :)
More than you get now.... probably.
For more info than that you have to be just a touch more specific, like what mods are you running, what boost would you intend running and how close to the edge would you ask the tuner to take it.
Re: Re: ecu upgrade
No mods the car will be standard, and as for boost whatever the engine will take.
TOO many posts.......
Hi Andy, you`d need a pump, i had a sard fuel reg aswell, recirc dump valve, boost controller optional, cus with Autronic boost can be controlled via the ecu ;)
Mines @ 379bhp @ 1.67bar ;) i wouldn`t recommend going any higher with the boost :confused:
Nice to see you today mate.......... :D
Re: Re: ecu upgrade
staffi said:
Hi Andy, you`d need a pump, i had a sard fuel reg aswell, boosr controller optional, cus with Autronic boost can be controlled via the ecu ;)
hi mate nice to see you today. The price you said today will the pump be included?
Autronics on an otherwise bog standard car is a very strange way of going about modifying.
Filter and exhaust is generally first, followed by more boost and a remap/mappable ECU as needed.
What is your final power target?, if it is not huge you may be wasting money on an Autronics as there are cheaper options out there.
1 - 8 of 8 Posts
