1 - 20 of 20 Posts
hi all
thought this might be interesting
note this was a rolling start from and amp;lt;2000rpm in 1st which actually makes it about a second slower to than if you did a standing start
timing was pulled between 4500 and 5500 so will add more fuel here
slight knock at top end also so might take a degree out of the timing
MAP is in kpa (absolute) so 200 would be 1 bar, etc
i have the boost set to 220 (1.2 bar) to 6000 and then are tapering it down 1.15 at 6500 and 1.1 at 7000
02 sensor kaput so no reading for it
andrew
<font size|EQU| 2 >
RPM MAP WG% O2 INJ TPS KNK ADV
2163 18 87 0 1 11 0 22
2073 19 87 0 1 11 0 20
1998 19 87 0 1 11 0 18
1927 20 87 0 1 12 0 16
1849 25 87 0 1 15 0 16
1807 52 87 0 7 39 0 20 0secs Start Gear1
2500 107 87 0 11 73 0 17
2703 115 87 0 15 100 0 15
3027 129 87 0 22 100 2 12 1 sec
3436 155 87 0 35 100 1 7
4029 199 87 0 63 100 6 1
4770 232 86 0 80 100 30 0
5501 227 81 0 88 100 68 5 2 sec
6225 218 81 0 95 100 55 6
6816 214 81 0 99 100 98 6
7324 216 79 1 53 11 87 30
6485 21 86 0 3 17 42 32 3 sec Gear2
5668 104 87 0 28 100 29 13
5509 163 87 0 64 100 24 3
5747 237 85 0 97 100 62 5
6074 240 74 0 99 100 79 5 4 sec
6451 220 70 0 97 100 78 6
6791 213 83 2 99 100 62 6
7048 216 82 0 99 100 72 6
7339 221 77 0 99 100 77 7 5 sec Gear3
7577 181 80 0 21 11 72 32
6576 17 84 0 5 55 45 24
5651 210 87 0 87 100 62 3 6 sec
5755 246 77 0 97 100 57 3
6025 230 68 1 92 100 56 5
6184 215 87 0 89 100 120 5 (knock)
6352 215 87 0 93 100 50 6 7 sec
6553 221 85 0 99 100 149 6 (knock)
6694 222 81 0 99 100 55 6
6854 220 77 0 99 100 76 6
7008 218 74 0 99 100 91 5 8 sec
7128 217 70 0 99 100 98 5
7239 217 66 0 99 100 82 5
7367 215 64 0 99 62 93 16
6956 39 83 0 6 11 52 32 9 sec Gear4
6144 110 87 0 32 100 49 12
5493 185 87 0 78 100 29 3
5558 247 81 0 94 100 51 3
5642 236 70 0 89 100 100 3 10 sec
5729 220 67 0 83 100 68 3
5836 214 87 0 83 100 72 3
5938 222 87 0 92 100 80 5
6025 226 85 0 93 100 46 5 11 sec
6184 222 81 0 92 100 77 5 160kmh
6278 221 80 0 92 100 83 5
6352 221 79 0 95 100 65 5 12 sec
6407 220 78 0 95 100 81 5
6507 219 77 1 98 100 60 6
6565 218 75 0 96 100 62 6
6623 218 74 0 98 100 50 6 13 sec
6706 216 73 0 98 100 55 6
6767 216 72 0 98 100 115 6 (knock)
6841 215 71 0 99 100 81 6
6904 214 70 0 99 100 76 6 14 sec
6969 215 69 0 99 100 82 5
7008 215 67 0 99 100 93 5
7048 214 65 0 99 100 91 5
7101 214 64 0 99 100 66 5 15 sec
7156 214 62 0 99 100 60 6
7225 212 60 0 99 100 67 6
7267 211 60 0 99 100 54 6
7034 62 81 0 8 10 50 32 16 sec Gear5
6194 14 87 0 12 100 43 22
5276 135 87 0 44 100 21 4
5359 248 76 0 88 100 31 0 17 sec
5413 231 67 0 83 100 39 0 (pulling timing)
5469 218 87 0 79 100 54 2
5493 215 87 0 80 100 61 3
5525 224 87 0 83 100 43 3 18 sec
5567 230 83 0 85 100 56 3
5600 228 78 0 84 100 50 3
5642 221 77 0 83 100 49 3
5677 219 87 0 82 100 56 3 19 sec
5703 224 87 0 86 100 55 3
5738 229 83 0 88 100 70 3
5782 226 80 0 86 100 54 3
5809 224 78 0 86 100 61 3 20 sec 200kmh
5827 220 77 0 87 100 60 3
5864 219 77 0 87 100 62 3
5892 219 77 0 86 100 89 4
5910 219 78 0 86 100 56 4 21 sec
5967 219 78 0 86 100 58 4
5967 219 78 0 90 100 61 5
5996 220 78 1 90 100 39 5
5720 64 87 0 7 11 43 32
Fit a bigger fuel pump, there is a bosch high pressure high fits into standard place easily. Then raise max boost to 1.4 with thesame curve at the top as you have although I like to set it to 1 bar at 7000rpm but looks good anyway. Ha Ha
Did you get caught??
i still have some fuel left at 4500 to 5500 so will add more here but no more at 6000|PLS| as injectors at 99%. egt is touching 950 on the top of 5th gear also so yes need more fuel. once she's right at 1.2 then will turn it up to 1.3, then 1.4, etc
do you know the model number of the bosch pump?
andrew
Yes I do know the fuel pump number but its at work, Ill dig it out and send it to you. Do you measure the temp of the turbo before the turbo ie in the manifold or do you measure after the turbo. I ask this beacuse there is a temp drop through the turbo so if you measure before this is OK but if you measure after this will make the real temp approximately 100 degrees higher!!
What ECU is it, Motec??
The probe is in the number 1 exhaust runner about 2 inches from the port. I figured this should be the leanest.
ECU is link, it came with a basic MAP and then I have been developing it from there. Is the Bosch pump this one PN# 0580254-984 ?
Andrew
Sorry wasnt in work today get the number after the weekend. Never had anything to do with link used a bit on autronic though. Heard that the link is quite good for its money from a friend in NZ.
Just reading your page, interesting on the ECU side. The higher boost we get with the GEMS is as you suggest from a smaller jet between the T piece and the compressor housing. 1mm standard but try a 0.8 we have used 0.6 on GRP N and lower for engines with different pistons etc. With a restrictor on the turbo intake on rally cars though the boost curve has to be set measuring the vaccum between the restrictor and the compressor wheel to ensure that there is no over speed. You wont experience this on a road car because of the size of the standard inlet hole but be wary that when you change the jet in the pipework this increases the whole scale of the boost curve. You probably already know this but just pointing the obvious to avoid any mishaps!!!
Thanks for the settings. The boost control of the link is very, very good - possibly the best feature (unlike cold start - although ok now) so I should be able to safely limit the boost while getting it on boost earlier by making these changes. I always data log after making any changes to ensure there is not unacceptable knock.
Britton motor cycle company (remember daytona?) can make pistons (and rods) at reasonable cost, although those in the 6 are pretty good, so more a case of keeping det and temps under control to ensure there are no problems. Vr4 rods are an option although their are issues with these as well (journals). This company (denco) also make rods if need be.
Link is only 2 miles down the road from my office so why not support them? They helped tune my car and also cleaned it, which as I drive on dirt roads a lot (car always dirty) is nice.
Would appreciate the PN of the pump.
Andrew
Andrew,
great data, although I'm still trying to understand it.
Obviously MAP is Manifold Abosolute pressure, Inj is presumable injector duty cycle, KNK is reading from knock sensor, O2 is oxygen, ADV is timing advance but what is WG%.
If Inj is duty cycle I think you have to upgrade injectors or pump urgently as suggested by fastas. I'm trying to remember what it said in 21C Peformance but I wouldn't go above 70% duty cycle otherwise you risk lean outs that will cause detonation. Or have i missed the point somewhere?
Shame the O2 sensor was not working.
Yeah I am still trying to understand it too!
wg% is the duty cycle of the wastegate solinoid - the ecu cycles this open or closed. You set an initial 'guess' (so 87% means open 87% of the time) The computer then adjusts this up and down to try and maintain the boost you have set for the rpm (can set every 500rpm). The higher the initial guess is set the quicker it comes on boost but the more likely it is to overshoot (you can also set a sensitivity to help control this). I haven't altered any of the restrictors yet but will experiment with this too.
I now have a new o2 sensor and have got shielded one that should tolerate exotic fuels better. The standard mitsi is 4 wire (possibly wideband too) but v expensive. This one is 3 wire so am in the process of fitting it.
It's interesting to note that at higher rpm this actually starts to decrease so the turbo is not having a problem with this level of boost.
Have since increased the fuel in the midrange also. I had to turn the fuel up to control the knock and also to try and bring down the EGT. Definately need a new pump (and/or rewire)!
1.2 doesn't seem that high (although i have cold air, intercooler pipes, etc so may be getting a cooler/denser charge)
Makes me worry about those people who are turning up the boost without monitoring knock or egt.
Andrew
What link computer do you have ,Evo link or link plus
And why did you choose the one you have over the other
Also have you tried running anti-lag
I beleive that was a tme evo 6.5! And it got drilled by a evo4 and rs wrx. Akiwi were you there? where are you from?
No wasn't me, as mine is a blue 6. The photos on my site were taken in Timaru though...
Got the evolink as I wanted something that was plug and play...unfortunately it wasn't quite that simple and on reflection i may as well have got the plus and adaptor cable.
Haven't tried the antilag program yet and to do proper antilag you need a way of holding the throttle open more than is possible with the stepper motor, etc.I'm not too worried about boost at idle but keeping it on boost as much as possible when driving through the twisties and changing gears is good so...
What I am going to experiment with first is activate the secondary air system (by turning solinoid on) and then retard the ignition and increase the fuel on row 1 (normally the fuel is turned off or close to zero and ignition is advanced to the max). This means that on the overrun I should be able to keep the turbo spooled better and reduce lag - will see!
Andrew
Discussion Starter · #17 ·
Sorry Andrew. This was an EVO 6.5 and owned some guy called Scott Brady
Blair or should i say Mr Gabities
The EVO 6 at the drags got 13.91 sec 1/4 mile. The WRX RA owned by a local Andrew Kitching got 13.27
Now the EVO 4 got 15.32. Which beat me in my 1800 (then standard) by .06 of a secound
Andrew if you want to run anti-lag you need to get a solenoid to hold the throttle open when anti-lag is on.
Discussion Starter · #18 ·
Part no for the fuel pump,
0580464997
Andrew be careful when doing ALS maps if you want to put in feul at the base line, too much fuel makes the turbo into a gas turbine and seriously creates some heat, should have fuel limits in here.
Discussion Starter · #19 ·
fastas
thanks for the PN. the bosch agent reckoned a rewire may be needed but will check figures and have wired a multimeter to the pump
yes will go very easy on the fuel and at this stage will only increase above 3000-4000...can you reccomend a duty cycle?
andrew
Discussion Starter · #20 ·
If (!) you have access to a mut 11 ,with flight card,you can record similar information !
if its any use to anyone i can possibly help
1 - 20 of 20 Posts
