1 - 2 of 2 Posts
Need help. My heater control selection isnot working properly. There is no issue with generating heat or cold air etc but the problem is changing the air direction to the windscreen or footwell. :wallbang: this is annoying especially with all this rain we are having currently and my windscreen steams up.
Could this be a easy quick fix thats cheap or should I just take it to CCP Motor developments in Sandbach?
Its usually the little things that are the most fustrating. any advice would be great .
Thanks :mitsi:
S.Wales R.O./Electrician
Mine did this the other day.
To do some diagnostics, I unplugged the motor(s) swapped the plugs (just about reached) and moved the controls and it started working.
Refitted the plugs the correct way round and it was fine, may have been a gummed up motor.
ETA: You can get to everything behind the stereo.
1 - 2 of 2 Posts
