E8 Genuine FQ 400 6 Pot Alcon Brake Calipers With 343mm Discs
Got a extremely rare set of Alcon brakes of a evo 8 fq400. There were only 100 fq400's made. They are exactly the same as the kits you can buy, but have Mitsubishi cast into the caliper which gives them a cool OE look over the normal Alcons. They come complete with everything you need to fit brackets etc. Will fit all evos 4-9
The 343mm 2 piece discs are the biggest discs you can fit under the standard wheels which looks great as it fills up all the space behind the wheels.
The brakes are a great upgrade over the standard Brembo's if your car visits the track.
The paint on the calipers is not great as they could do with a refurb. They still work fine not seized etc. Godspeed to a refurb service for these and can also fit stainless steel pistons which is what I would do if keeping them.
The discs and pads are worn and will need replacing soon. I will put pics up later.
With all that in mind, looking for £800.
Located in High Wycombe.
07834063821
