Hi just wondered if anyone could help me out. Just tried to remove NSF driveshaft. Got the outer side out ok but cant seem to get the inner joint out of the gearbox. Tried pulling/gently levering it out but dont want to force it and break anything! The shaft I have got to go on has a 'female' splined end so im assuming there is a 'male' splined shaft coming out of the gearbox. Should the driveshaft just pull off this male shaft?
Cheers if anyone can help.
You need to overcome the spring clip on the splined shaft.
I usually use a crowbar and just give it a tap and it will pop out.
Nice one! That link was very helpful. Just going to get breakfast and get ripped in as the weather seems ok. Fingers crossed it comes off this time! :hammer:
Ok got it sorted now, just changed the driveshaft. Just need to put some more oil in now. Cheers for everyones help, saved me a few quid there. :smthumbup
