Guest
·OK, so the normal headlights are pants but my E6 has just developed an annoying gremlin. The drivers side headlight will not work on the dip setting - just the side light bulb stays on. Passenger side is fine. On side lights only and on full beam both lights everything is OK, so it does not seem to be a blown bulb or fuse problem. PIAA driving lights work fine too. None of the 3 sets of wires feeding into the main bulb seem to be loose or damaged and the bulb itself seems fine.
If there are any budding electricians out there I'd like to hear from you. You're welcome to have a poke under the bonnet for those of you coming to the Southern R/R day this Saturday. I'd rather not drive around with just the PIAA's and amp; sidelights on looking like a Max Power job.
Steve.
Steve.
