1 - 8 of 8 Posts
hi all,
hope you all understand my question.
i have E6 ralliart ecu in my car, but is there a diffrence betwean the standard ecu and the ralliart ecu?
and i mean then the rpm section.
when is the end off the rpm.
i believe it ends at 8100 rpm.
is there a other redline on the dash by the ralliart ecu then the standard ecu/dashboard redline??
thanks
If you mean the rev limiter - then as far as I can see, the Ralliart ECU is the same as the standard Evo - 7606 revs.
Not sure what you mean with the dash.
yes thats it
the rev limiter
my ends on 8100 rpm
but when you buy a new E6 ralliart (back then) with that ecu in it.
do they change the rpm gauge also then.
is the redline on that rpm gauge also diffrent??
Do you mean the Evo 6 supplied by Ralliart? If so, then I don't think any of them were fitted with the Ralliart ECU. The Ralliart Evo 6 will still have a normal ECU.
I'm not an expert though, so I could be wrong!
Is your galant tachometer reading the same pulses as the lancer tacho? Maybe the calibration is different?
What RPM is the engine idling at?
my tachometer in the galant goes the same as the evo.
my redline is diffrent.
but thats not the problem.
i have also a apexi avc and a apexi afc in the car on there is also the rpm.
why i whan to not al this is for a g-tech.
i try to get a good g-tech session.
but i have to know what the redline is in the ralliart.
and what about the ralliart ecu.
ralliart have a own ecu for the E6 i think also for the other evo's.
a that ecu is diffrent from the standard ecu.
The RPM limit is the same for both standard and Ralliart, the main differences are very high boost cut, increased timing, leaner fuelling and lowered fan operation temps..
1 - 8 of 8 Posts
