Anyone know their way around diesel fuel pumps?? L200 threw up a code 18, and it seems it commonly means fuel pump failure due to wear. BUT, on this 1 which is low miles for age, and had absolutely no issues till the fault appeared (told usually causes intermittent limp mode during use, till eventually happens on start up - ie wear), i ended up testing the actual pump speed sensor as per workshop manual, meant to test resistance, but it gave no reading, so tested continuity, no continuity. So I think it is simply a sensor failure. No sign of physical damage
So, can anyone tell me where i can get a replacement sensor from, besides buying a complete replacement pump. Its a magnetic type, and has the numbers 592 20 stamped on it. 3 wires to plug, but only 2 to sensor
Gas Auto part Household hardware Cylinder Automotive lighting
