1 - 9 of 9 Posts
Anything right under the bottom of the strut, can't see for the brake hose, sometime find an allen key adjuster under there on some of the WP stuff.
I'd go with this one.
The D2 et all struts adjust using an allen key shaped rod that goes through a hole at the top of the piston tube. See if you can fit any kind of allen key in there.
Failing that, have you asked the previous owner?
Paul
maybe needed a tool? goes down the small hole in the top if it looks open?
ok boys sussed it the nob was at the bottom i just couldn't see it earlier as its up inside the tube a little way
both front and back where set to full hard !!
now gone for 10 off hard front and 8 off hard rear
car is sooooooo much nicer
1 - 9 of 9 Posts
