Hi
Ive got a e4 with e6 engine, apexi power fc (with MAF) etc.. It keeps cutting out only on light throttle or on idle. I can get it back if I just catch it with throttle.
Ive changed the throttle body over with a spare( comlete with throttle position sensor and idle cont valve) , blanked off the dump valve ,checked for air leaks with some carb cleaner, checked all the wiring not loose. The fuel pump seems to be running ok, Ive taken the rear bench out so i can hear it.
It always restarts sometimes it cuts out straight away...
So annoyed now Please any suggestions??? Air flow meter ?? (ive also monitored it using power fc.cant see any dips in graphs) :wallbang:
