the problem started when the car suddenly stopped while driving normally. No spark and no fueling. Diagnosed the problem to be a faulty crank sensor. After fitting new sensor, the engine started nicely but as soon as the clutch is depressed the engine started to misfire quite badly. changed the plugs and engine fired up fine. In all, the engine probably ran for 40mins today in the garage.
When the clutch was depressed yet again for 1st gear the engine stopped completely and won't start again. Now, after examining the old crank sensor, it appears to be alittle damaged, seemed like something has been rubbing on it.
My fear now is that there is excessive crank walk and the disc is actually rubbing on the crank sensor whenever the clutch is depressed. Does the 4G63 suffer from thrust bearing failure? Or could my crank be twisted?
Now, with this latest find about the crank walk, its becomming clear as about a month ago, the engine suffered a complete engine oil starvation when the oil filter was damaged when it hit an uneven patch of road. So, the engine probably did a good 10mins with the engine oil gushing out and maybe a minute or 2 without any oil.
Luckily the problem was rectified early and it seem to have saved the engine until this happened today. In fact, the engine was happy revving away until the clutch is depressed.
Can it be
1.) Damaged crank
2.) Worn out thrust bearings
3.) complete mess at the bottom end?
Planning to put the car on a ramp tomorrow and do a simple check with the sump off. Anything particular to look out for?
really appreciate any help guys..
Can it be
1.) Damaged crank
