1 - 9 of 9 Posts
Just wondered if when anyone else has ordered a new crank bolt from mitsubishi or ross sport if they get one without being able to put a breaker bar in the end.
Just building my engine and it came in useful when coming to undo it that I could put the breaker bar in and no I won't have this option if i strip it down again. Can take a pic if needed
1 more quick question iv done a search and people tend to use different methods. On tightening the crank bolt the factory manual says to put some oil on it and other people tend to put a drop of lock tight on then tighten it. From experience what do you guys recommend
BAD BISH
Yes, I got the same with washer from rosssport
I take it you can't get them any more then. Never mind, thanks for the reply though. Did you use oil or lock tight when you torqued the bolt up
Looks ace mate. Just been looking at that arp one this afternoon on the net and might get that :thumbup:
BAD BISH
Thanks!
go get one mate :smthumbup
Why not overkill? :mhihi:
1 - 9 of 9 Posts
