1 - 8 of 8 Posts
hi all,
hope this is the right forum, car failed the MOT , 96 E4 on a lower arm , called the local dealer and a few traders on here but no one has stock , the code i got from the dealer was MR316447
i checked on euro car parts and seen this
Q-Drive Suspension Arm (Front Axle Left)Product Code: 61569063J
http://www.eurocarparts.com/ecp/c/M...3ef689b8e8e1e06e4ca55aba87820a18c7eefe&000320
would this be the same? hope so as i cant find one anywhere that has actual stock
thanks in advance
acting daft since 1969
whats wromg with the arm on your car now ,you can replace the bushes and the ball joint quite cheaply, no need to by an arm which is cast iron so hardly likly to ever go wrong
Eurocar parts listings for evo are wrong. I deal with them daily and half the parts listed are for standard lancers not evo. The track rods are wrong and the lower arms listed are for standard lancers not the cast arms of an evo 4
seen this on mlr, but havent got access to a press to get the old ball joint out, i will call a few engineering shops as the dealer is out of stock and said its could be 2-3 weeks!
Euro car parts need to improve there compatibility listings so much stuff is wrong!
Support your friendly independent specialists :thumbup:
yep Euro was wrong just ordered it and went to lift it sat morning and totally wrong and then the fella goes on to argue its right so up comes the email with the diagram from the dealer - oh our system must have the wrong number!
ross do you guys have it on stock , if not if it was ordered do you know a rough eta?
Ross Sport
Im sure we can sort that for you, or any of the other guys on here that supply OE parts :thumbup:
1 - 8 of 8 Posts
