Guest
·To reduce the heat in a turbocharged engine is always a good thing to do. There is an item called radiator shroud/cover which is supposed to channel more air into the radiator and the other item is called the front under panel/sump guard which is supposed to aid cooling in the engine compartment. Any comments on these two items!
I have already had a Ralliart themostat fitted which is a straightforward replacement of the std. themostat. After fitting it I find that the fan now kicks in earlier and I think is about 5C earlier than usual.
