Guest
·Whilst trying to fit my battery today which wasn't very succesful I noticed
that the fan on the back of the radiator was loose.
It seems like the fan is not even attached to the motor and can be moved
a couple of inches back and forwards and up and down.
This means that the car could possibly overheat due to the fan not working.
I can only presume that this will result in engine damage if the temprature
gets to high.
Is it an easy job to remove the fan assembly and will I have to replace my
coolant fluid as I will have to disconnect a couple of pipes or can I just top
it up after re-assembly.
Also is there a special bolts needed to re-attach the fan to the motor. I am going
to attempt to fix it tomorrow so any help would be greatly appreciated.
Many Thanks
Skeletor
gets to high.
Many Thanks
Skeletor
