Hi all,
I have a bit of a wiring gremlin and I wonder if anyone has experienced the same kind of thing.
All of a sudden last night, the horn on my Evo 8 started going off constantly. No one was in the car, no one was near the car so I had to pull the fuse or relay to stop it. Today I've been out there with the volt meter, disconnected the horns themselves so I don't get deafened and reconnected both the relay and fuse.
When the ignition is in the off position the horns get a constant 12v so keep going off. When the ignition is switched to position 1 or 2 the voltage flow stops. Now I have tried multiple relays of the same type however none of them seem to have made any difference.
Is anyone aware of any issues that might cause this at all? And more so what might fix it?
The only thing I can think of is that some water may be loitering somewhere it shouldn't be, but that doesn't make a great deal of sense as if that was the case, when the ignition was on the horn should still be active.
Any help is appreciated, Thanks in Advance.
Andy
Andy
