Hello T1000
The correct place for a feed for a boost gauge is from the rubber pipe that comes off the plenum chamber/inlet manifold, that runs to the bypass valve/dump valve.Its the grey pipe thats about 4-5 inches long.If you take a feed off there you won`t go wrong. Good luck. Regards, SIMON.
