Guest
·Hi Lads,
Anyone know what compression pressure i should have?. My car is the 1800GSR (4G93T), Done a test last week and got a reading of 185psi on all 4 cylinders but i have no info on what the standard readings arehttp://194.93.140.171/graphics/sad1.gif border|EQU| 0 align|EQU| absmiddle >.
I'm trying to sort out what's causing my coolant to overflow so much after a good on boost drive. I've done a coolant system pressure test which was rock solid with no pressure drop!, now i've done a compression test which showed all cylinders giving the exact same pressure (185psi). So that rules out a head gasket problem (doesn't it?).
Any ideas??.
Any ideas??.
