Hi Ian! The miss fire was just the plugs! Thankfully! It ran at Brands perfect allday considering the car ran about 150-160 laps! I like a bit of drag :gay: but I'm not that interested in getting really really low times, just the best I can get from my car.Setup/Handling first every time Dan, unless just doing drag then power can make up for a lot, maybe think about a map check to make sure all is tiptop especially if you still have that misfire??, stock engine should be good for awhile with mods you have as long as the mapping is spot on
Ian
Burgers22 carried out a log on my car and everything is spot on, minimal knock if any at all, inj. duty cycle fine everything spot on! So I'm happy with the way the car is running now, just maybe turn down the boost to 1.65-1.7 bar for a bit of extra safety.
What coilovers would you recommend from your experience Ian, PM if you want to save the thread going off track slightly! Or though I seem to have made my mind up now so could turn the thread into another 'what coilovers do I need!?' thread.
Just for the record, I don't really care how comfortable/uncomfortable they are as I don't use my car as a daily driver, so track based suspension is what I'm after
