Coilovers (Fun) or Forged (safety)
1 - 20 of 83 Posts
I'm stuck between the 2 :eek:
Do I go for Coilovers to strengthen the grip, braking etc.. side of things or do I play it safe and forge the engine so she doesn't blow on me along with sorting a few other things for a little extra safety ie. fueling and that..
The only coilovers I would be interested in is the Exe-tc Fast road set-up, which would cost roughly £2000ish once fitted (About £2500ish With top mounts) And lets say a forged engine with some added fueling bits would about £2000 aswell... Would that sound about right? Please correct me if my estimates are way out!
Or maybe you have some other ideas? Say, if I were to have £2500 max to play with. - What would you do?
Help!
Cheers for any info - all appreciated!
Dan. :D
Help!
Dan. :D
if it were me i would forge the engine if i could do it all over again i would have a manky looking forged engine lol
Nathan took you out in mine at Brands didn't he ?
How did you find the coil overs ? even though I have lower spec ones compared to the ones you are considering
Would your car with standard suspension be capable of handling a lot more extra power eg shouldn't you forge the engine after or at least at the same time as doing big power mods ?
Same for brakes ?
Just my 2c
Hi Mate,
If you are going to do more trackdays/sprints then go with set up, If you want to do more of the pod and fast road go for a forged engine.
As for turning down the boost on track you can do this to be safe but with a good set up coilovers/brakes you would be just as fast if not faster..:eek:
Lee
Same for brakes ?
Just my 2c
Your car felt good Raj, the difference between your coilovers and my standard suspension was night and day. This is why its a tough choice. Brakes are not a problem I believe with correct fluid, pads etc.. the standard set-up is fine..
I don't consider my car to have big power mods, the bottom end could go on for 50000 miles without a problem, but, it may not, as I'm entering the sprints this year coilovers would be a great asset for times etc.. but forging, obviously, wouldn't have much affect apart from peace of mind... So I'm leaving it up to you guys!!
Hi Mate,
Lee
Good point Lee! Coilovers would be much more affective than the extra boost lol! So that may be my answer right there I like the pod but only a few times a year, so would not be a problem!
Go for coilovers, then when she blows up, you'll have to forge her too :smthumbup
Good thinking... But she'll probably be off the road for a long time!
is it that cheap to forge your engine 2k ? :confused: i thought it was alot more than that. but maybe you could compromise and get suspension and get a half forged engine from Norris ? e.g get some steel rods for 1k. strong bottom end then. and the rest of your money on some decent coilovers. :D
Banned
Don't believe you... You'd get a loan... or another loan... to get it done and back on the road
But Anyway, do as Blair suggest, Coilovers, Unless you prefer straight lines only and brick walls on the bends...:crackup::eek::crackup:
The steel rod thing from Norris will end up costing about £1300-£1400 and that only really leaves a £1000-£1100 for coilovers inc. fitting and set-up. Had my heart set on the Exe-tc coil. but maybe go for Tein or the like instead? I don't really want to sacrifice quality if that makes sense?
i know what you mean. i guess if you've got your heart set on exe-tc then get them, they won the coilover mlr test, and they look the dogs danglies. your engine hasn't done many miles yet, plenty more life as it is so u could wait a while for that....
Discussion Starter · #18 ·
bite the bullet man and do both :coolsm:
I really would love too! This will pretty much be 'the last' big mod I do for ages (don't we all say that!?) This is pushing the budget as it is but feel it has to be done, whatever it turns out to be! I know whatever I have done I will probably regret not doing the other!! Or will I?
TOO many posts.......
You might REGRET the one over the other and you know the one i think...:smthumbup
1 - 20 of 83 Posts
