1 - 3 of 3 Posts
Discussion Starter #1
My EvoIII has suddenly started slipping the clutch very badly, it also disengages at the very top of the pedal when it used to be near the bottom, can the adjustment go haywire on the clutch or is this a symptom of needing to spend out for a new clutch? Also what should I expect to pay for a new clutch? I'm sure many of you chaps have been through this before.
Stevieb
Ours started this back in Jan this year.
First of all we cleaned the clutch master cylinder and put fresh brake fluid in it. This brought the pedal back.
But the clutch has started to slip again under pressure. Currently getting a new clutch.
Sorry m8 seems that this is the early sign of the clutch on it's way out. I spoke to a few people and the one we are going for is off [email protected] as he is doing us a good deal on a exedy clutch.
Discussion Starter #3
Thanks for your reply Evo1man, it appears that the thrust operating arm bent holding the clutch slightly open causing the slippage and pedal difference. O well, picking it up later today, hopefully all working again.
stevieb
1 - 3 of 3 Posts
